VINS you want "fasted"
And now the bloody flapper is jammed slightly open. Lazy as all f**k in 3rd-5th (very hard to convince it to make much boost before you run out of revs), but will make 12 psi in 1st, which shouldb't be possible with a 5 psi spring and controller set to <10 psi. Methinks I'm lucky it jammed where it did, rather than fully closed. It's actually a well weird situation. Careful examination of what's happening in the back of that housing when the gearbox comes out and all the other stuff (injectors, AFM retune) is supposed to be done, next week.
The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
