hello... id love for someone to be able to help me with fasting my vin to identify the vspec/non v spec etc and anything else which may be interesting
BNR32305342
thanks in advance :P
here you go
Your model number is KBNR32RBFSAA. Using the below link to decode all the letters you can see its a vspec.
http://www.users.on.net/~goofyhsk/info/chassis_plate.html
Could I get my vin fasted please, I've got some weird letters in my model code :S
BNR32-003362
KBNR32RXFSLMZG < dont know what the M,Z, and G mean :P
thanks.
I ran your vin through fast and got you this.
To be honest i have no idea what the M, Z or G mean in your model code but i have only ever seen them on r32 gtr's that were built in 1989.
Maybe someone else can shed some light on what these 3 letter mean and why they only seem to be on the model codes of early r32 gtr's??
G'day,
Could someone with FAST do a vin & engine check for me if possible.
The VIN is ECR33135365.
Engine no is RB25277413A
Thanks in advance.
Cheers
Grant
I have been doing a lot of searching around on the forums for the answer to what the last letters mean on the model codes for the early model r32 GTR's (L,M,Z and G).
cameronbnr32 and garrysandy the only info i could find for you guys (and any one else wondering) was a post from funkymonkey back in 2004.
From what i read the letters L and M, which occupy Positions 8 + 9 in the model code, are known as VS Sign (VS Options)...
L means it has Projector Headlights
M means it has both climate comtrol + upgraded stereo
Letters Z and G occupy Positions 10 + 11 in the model code and are known as Pack Sign (Package Extras Sign)...
Z Im still not sure what it means but some guys believe it might be to do with the interior trim. RellikZephyr Thought Z = Black Interior Trim.
Cant be confirmed unless funkymonkey or someone else knows for sure what it means.
G from what i found means ABS and a Viscous LSD
Hope that helps a lil for you guys wanting to know.
Below is funkymonkey's original post from back in the day
Here's the factory Extras that are indicated by the last 7 characters ona 1989 -1991 R32
VS Sign
Position 1
Blank = Standard Headlight
L = Projector Headlight
Position 2
Blank = Standard
P = Electronic control active Full auto air-conditioner (Climate control system I assume)
Q = Electronic control active Sound System (Upgraded Sound System?)
Z = Cold District Specification
M = P +Q
V = P + Z
W = Q + Z
T = P + Q + Z
Pack Sign
Char	Pos:	1   	 2
A	Standard	Standard
B	4 Wheel Anti Skid (ABS?)  GTR Steering Wheel
C	Sunroof   	 Type M Specification
D	GT Auto Spoiler (Front Only)  Viscous LSD
E	GT Auto Spoiler (Front and Rear)	B + D
F	B + C
G	B + D
H	B + E
I	C + D
J	C + E   	 GTE Special Seat
K	B + C + D	J + Viscous LSD
L	B + C + E
SS 	 V Selection
Position 	 Number: 0	1	2	3	4
1 With ASCD - RB20E RB20DE
  Super HICAS RB20DET 2WD  S	Y  Y
1 Audioless (All Cars) 	 S  Y	Y
2 185/70 tyres + 14 inch rims (CA18i)	S	Y
2 15 Inch Alloy Rims 	 S 	 Y
3 Electric Side Mirrors (CA18i)  S	Y
3 Fender Mirror (All Cars)  S  Y  Y
3 Rear Wiper	S 	 Y	Y
S = Standard (ie. does not apply) Y = Vehicle is equipped with this
G'day,
Thanks in advance.
Cheers
Grant
dont know about doing an engine check but here is your vin
makes sense - cause the whole chassis code from the vin i posted ended in LMEC
the car does have the projector headlights (L)
it could have climate control and the upgraded stereo, but they have been ripped out (although some parts are there)
the E corresponds to GT auto spoiler front and rear apparently - and it is a type M r32 with a sliver GT badge on the side
and it does have a sunroof which is a type M spec item
bit of food for thought i suppose :woot:
bit of food for thought i suppose :D
Yeh i tried with my r32 gtst model code. I have the LMEC on the end of my model code and it worked out fine.
I have the projector head lights. I have the climate control and had the "upgraded" stereo. I had the GT auto spoiler and its a type M r32 so thats how i decided it was all pretty right and close to the mark.
If any one definitely knew any different im pretty sure they would soon post in here.
Still dont get why nissan changed everything from 1991 onwards with model code the R32 GTR's . Did make it a lot easier to decode the model code though
Edited by babyskyline
can you do 350Z checks? checking for a friend... have a suspicion a dealer is doing a dodgy, need to know if it REALLY is a "track" model and if it came from the factory with the REAL track rims, the lightweight ones...
EDIT: hmmm... i don't think i've been given a VIN, i've got the engine #
VQ35037314
and this
JNIGAA233A0010029 - being a Zed, should it have a Z33 type code somewhere? - It's OZ delivered obviously
My friend only showed me pics, i saw brembo's but the rims were the non-track rims... the track rims weren't an option were they? I'm just wondering if they saw her coming, maybe did something with the rims, or perhaps the brembo's were an option and it's not really a track model?
is there a button in the cabin somewhere to check for stability control?
the other thing i thought with 'fast' is that if it said it came from factory with the lightweight rims, i would get her to ask the dealer where the hell they went!
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
