thanks Chook, do you know what the A, AP and C means in the model, does anyone know?
I have a list for first 13 codes, 14 to 18 are the options, listed for you earlier. eg 'A' in #15 means rear wiper, P in #16 is big spolier. Dont know of any lists the cover codes 14 to 18. Just a matter of translating them.
http://www.skylinesaustralia.com/forums/in...t&p=3718792
can someone please fast
6U9000ecr33103232 and including options
appreciate it very much!
thankyou
Here is your fast mate. You will have to hit up chook to translate your options for you...i cant translate japanese
hey,
Can I get some info on this vin please :D
HR32002953
Also,
Is there any way of finding out what year the car was made?
(have a non- complied import that seems to have alsorts of parts on it)
Cheers,
Is it a non turbo or did you leave out a letter in the vin by any chance??
I couldnt get it to work in nissan fast. Need your model number also if you can get it.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
