hey, i downloaded nissan fast and when i put a vin in, either mine or someone elses it sais
INPUT VIN CODE, MODEL, OR MODEL SERIES. USE TAB KEY TO MOVE CURSOR
is all i have to enter the vin number into the top left hand box that sais VIN Code
Sometimes fast doesn't have info on a vin, don't know why this happens. Try putting in the vins that have been successfully fasted and see if you get results, if you dont get results then you havent installed it correctly.
Well i swear I have installed it correctly, I mean there isnt much i could go wrong. I tried a few nissan part numbers and they work fine. When i enter the vin number it has yellow background, does this mean anything?
Owell dont wanna off topic too much, could someone please give me details for HCR32020393
cheers
cheers
I get nothing from that vin with my version (most likely have the same fast setup as me)
Hi all,
That's my first post here :P . I will very soon get a R34 GTR and I'd like to check the model my chassis number is :
BNR34 000277
Can you tell me if Nissan FAST software provide the following data :
Max laden weight ?
Max rolling weight ?
Max load (front axle) ?
Max load (rear axle) ?
I've never seen anyone being able to provide these data.
I have the owner manual and the workshop manual but they do not help.
Alexis
ps: I'm from France by the way
Hi all,
BNR34 000277
Max laden weight ?
Alexis
Nissan fast doesnt tell any of the above things you asked as far as i know....
Max laden weight ?
Here is your fast mate.
Edited by babyskyline
thanks for you quick response mate, much appreciated !
My UK importer just informed me that chassis number is BNR34-000297
Do you mind to check this one ?
Max laden weight ?
Hi All,
Just installed it only to then read back 2 pages to see it only goes to 01 so won't find my V35 anyway. At least I can see my old 33!
Would someone with the new version mind doing this one: CPV35-600363
Thanks.
Hi All,
Thanks.
You might get a faster reply if you pm chook as he has the 2008 version
Im onto it.
thanks chook!
i am assuming that is privacy glass and sunroof but what is the other one at the top 'CLAS8'?
also, any chance of getting a tip off on how to acquire a version of the one that will show my model, pm if needs be.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
