Trying to find out of my gearbox has a push or pull type clutch..
It probably is a dumb question but im running out of options trying to figure out if my new clutch will go in or not, f**k r34 N/A's and their assortment of parts
Hopefully fast will tell me. It worked for my diff :happy:
er34010972
Thanks
this is the illustration of gearbox and clutch with part numbers
Edited by SkyHi_33
Thanks alot baron. Can i have a screenie of it with the list of factory options (if any) ? Thanks again mate
Big rear Brake
Super fine hard coat
advanced aero system
rear fog lamp
multi display meter
audioless
rear wiper
cheers
Can you please check this VIN out - supposed to be a R32 V Spec Gunmetal colour, van you check colour & whether V Spec?
Engine Number: RB26037275A
VIN Number: 6U9000BNR32304958
Thanks for your help
regards Mike
Edited by Mike Rowe
I always find R32s ridiculously hard to understand, but it came with 17s from the factory if that helps. Build date fits with being a V-Spec. Colour code is KH2.
Its a vspec. Looks like you finally found one mike.
Im the opposite...i can understand r32's but 33s n 34s make no sense :P
Edited by babyskyline
Thanks guys, its excellent the service you provide!
Now just need to make sure the car is in good condition and get it for the right price.
The clour cod - does anyone know if that fits being the gunmetal grey?
regards Mike
can someone try this one please?
BNR34-004512
and whats all this jargon-> GGJPRWYR34ZDAAAKCD?
im not too sure what the rest means, i cant translate Japanese on my program but someone else should be able to help you out.
regards Mike
KH2 - Gunmetal Grey Metallic
so yes, same colour.
could I please get some help on my model codes for the 33 gtr, I'm trying to find out what exactly the car is and what it came with from factory
my model code is GGJPRQFR33ZDA-----
So far I have got:
G - 2 door
GJ - RB26DETT
P - ????? 4WD
R - ?????
Q - GTR
F - 5 speed manual ?
R33 - Model
Z - ????
D - ????
A - ????
thanks.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
