Trying to find out of my gearbox has a push or pull type clutch..
It probably is a dumb question but im running out of options trying to figure out if my new clutch will go in or not, f**k r34 N/A's and their assortment of parts
Hopefully fast will tell me. It worked for my diff :happy:
er34010972
Thanks
this is the illustration of gearbox and clutch with part numbers
Edited by SkyHi_33
Thanks alot baron. Can i have a screenie of it with the list of factory options (if any) ? Thanks again mate
Big rear Brake
Super fine hard coat
advanced aero system
rear fog lamp
multi display meter
audioless
rear wiper
cheers
Can you please check this VIN out - supposed to be a R32 V Spec Gunmetal colour, van you check colour & whether V Spec?
Engine Number: RB26037275A
VIN Number: 6U9000BNR32304958
Thanks for your help
regards Mike
Edited by Mike Rowe
I always find R32s ridiculously hard to understand, but it came with 17s from the factory if that helps. Build date fits with being a V-Spec. Colour code is KH2.
Its a vspec. Looks like you finally found one mike.
Im the opposite...i can understand r32's but 33s n 34s make no sense :P
Edited by babyskyline
Thanks guys, its excellent the service you provide!
Now just need to make sure the car is in good condition and get it for the right price.
The clour cod - does anyone know if that fits being the gunmetal grey?
regards Mike
can someone try this one please?
BNR34-004512
and whats all this jargon-> GGJPRWYR34ZDAAAKCD?
im not too sure what the rest means, i cant translate Japanese on my program but someone else should be able to help you out.
regards Mike
KH2 - Gunmetal Grey Metallic
so yes, same colour.
could I please get some help on my model codes for the 33 gtr, I'm trying to find out what exactly the car is and what it came with from factory
my model code is GGJPRQFR33ZDA-----
So far I have got:
G - 2 door
GJ - RB26DETT
P - ????? 4WD
R - ?????
Q - GTR
F - 5 speed manual ?
R33 - Model
Z - ????
D - ????
A - ????
thanks.
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
