(For some reason I can't edit, this has happened to me before =/)
I downloaded Nissan FAST and installed it all just find just to find out the Nissan FAST setup file is 16-bit, and of course 16-bit got axed in Windows 7 x64. :)
So when I try to run it asks for a CD, does anyone know a way around this?
umm kind of, I got caught by the same thing....thought win64 would be good to try without realising how much doesn't run on it (like flash for instance). anyway, it comes with MS Virtual PC so I installed Win32 on a virtual machine and use that.
Others might know a better way to do it?
hey guys, ive got FAST on a cd, if any one wants it let me know and ill be happy to send it out. for some reason i cant get it to work...
can some one FAST this vin for me please - er33012099
thanks in advance
I installed XP on VMware and got it working. :P
Here we are mate. :)
thanks champ, any info on the transmission???
I would really love to help you right now but not really that good at deciphering the model number yet.
GGKARENR33EDA-----
Essentially should tell you everything.
Hold on a sec I found a way to prove its transmission, it's an Automatic Transmission.
You can tell from the AT and to confirm that I checked the parts and you can see there it's an Automatic Transmission.
I just confirmed with my car (R33 GTS-T) that if it is Manual MT.F5 appears there.
Probably all been explained earlier, but for those who tl;dr.
So your car is an Automatic NA R33 Coupe 2WD in Gun Metal Grey. Not a bad cruise.
Edited by Alinys
GGKARENR33EDA-----
thanks for that... im stumped though as its got three pedals and a manual gear shifter... it must have been converted to manual down the track
here is yours mate
i have another quick question, how can i tell if this gtr i am looking at is a v spec or not? can u find this out on the fast software at all?
i say this because in 2 different adverts, one say its a v spec and the other says its just a gtr? is there an easy way to tell which is which by either numbers on the car or something physical i can look at on the car.
ok, i did a bit more of a search, and came up with this.
on the fast screen shot, where the model number is, if u look at the 6th character along it says Q.
Q = non Vspec
W= V spec
is this correct? if so the one im looking at isnt a v spec.
Hi people,
Im looking at going to Melb this sat to buy the following. Can someone do a VIN check and let me know what comes up.
1996 R33 GTR V-Spec
Model no: ggjprqfr33
VIN: BCNR33002497
Engine No: RB26050285a
Colour code ano K
Thanks
Hi,
Me again, maybe I need to get my arse on installing the software (what file do I need to use for Skylines both chassis no and parts)!
I'd like to find out anything special about this chassis no.
BNR32001945 - Supposedly '89 In black.
Cheers
Grant
As a thread "VIN's you want fasted" was pretty successful so I think we should restart it with some guidelines on what you can do to make it work:
1) Your VIN number is the Vehicle Identification Number from the Japanese factory. It contains your model number followed by the build number of you vehicle.
Examples:
- BNR32001000
- ECR33003928
- BNR34000897
When the car comes to australia the VIN number is prefixed with 6U9000 and you're Australian VIN number becomes 6U9000BNR32001000 (for example).
When posting VIN's all we need is the part of the VIN number after 6U9000.
2) The VIN number is found on the factory blue compliance plate.
3) The FAST program is no longer available for download anywhere as far as I know, is around 2.2gb so I can't just send it to you on MSN (sorry).
4) I do not work for Nissan (sorry again).
Hopefully someone can merge the threads or something....
6u9000bnr32303621 32 GTR DUDE
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
