Here you go guys
Oh, and Nismo Boy, how about you look at how everyone else has provided their VIN and supply me with the correct format - I can't FAST the numbers you have provided. Engine numbers and model numbers are no good.
Hey guys - First post here! Sorry to not give a proper introduction but this request is very urgent :)
Looking at a 180SX at the moment - bit of an epic saga that started in June.
VIN: 6U9000RPS13324593
Engine Number: SR20848988A
Thanks a bunch in advance~ :mrt:
*Corrected VIN number
Edited by Rundle32
Here you go guys
Why i posted the Aussie VIN is past my own common sense, sorry. Here is the correct one I hope.
HCR32-284478
More important than the photo would be looking at the factory build plate rather than the Australian compliance plate. Remember, the FAST system is a Nissan product and has absolutely nothing to do with the local bureaucracy. But in your case, you might want to look your car up on the RAWS site to see what that says too.
The VIN is 6T91MPAAAT1GVT001
I searched through one website and it said it was a blue 33. Which it is. But then it asked to pay so i said pffftttt. Tried searching through other sites and it says that it can't find it.
hey guys i got no idea what happens here but im buyin a r33 gtr not sure if its a vspec could sum1 please help and just anyother general info would be awesome.
BCNR33022988
GGPRQFR33ZDA A AA
the second one is the body num dont know if thats needed, thought id put it neways.
cheers.
The first one is the body number, and the second is the model code. That is the EXACT information that we need in order to look up the car. Others take note!
:D
(But I'm not on a PC with FAST right now, so I can't actually look it up - I'll try to do it later on tonight)
:thumbsup:
you're welcome - but I have no idea how to tell if it is a VSpec or has options - most of the program is in Japanese. Someone else might be able to tell if it is a VSpec from the screenie I posted though?
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
