Does it say if its series 1, 1.5 or 2?
Also what does Type M Mean?
Cheers
Brad
I'm guessing because the R33 was only released in 1993 its a series I, fast doesn't tell you that info.
Type M was an option I believe.
If you do a search on these forums im sure you find all the answers, i think the series 1.5 was basically a series I with a Series II engine, you can tell by looking at your airflow meter if it has pink sticker it is from a series II or 1.5.
6T91MPR12TXJPLOO1
cheers
wrong number . that is chassis code . you wand chassis number . should start with wgnc34 or bnr32 or what ever model youc car is . or 69u000 some shit if its in oz
Hi Fellas,
E-BCNR33-023798
As much info on this please, its meant to be a genuine lm edition so lemme know
Ray
July 1996
R33 GTR
Champion Blue
But it doesn't actually tell me limited edition or special model so not sure if R33 GTR LM.
Anyone else can confirm this?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
