Hi all, i'm new to this forum and have put a deposit on a R34 GT-T today!.
Would someone be kind enough to check this VIN for me? (I probably should have checked before paying the deposit).
Thanks in advance for your help!
VIN: ER34012606
fast request pls:
6U9000BNR32009882
thanks
Urgent FAST request please my good man :down:
BNR34005113
Ozzie # is 6U9000BNR34005113
is V-tech is good.
Cheers
Thank you very much BundyBear.
Would anyone be able to help out on the following:
* Colour: QM1 White
* 2K not sure (either 2k or 4s) most 2k
* MT.F5 5speed Manual
* HI.2WD Hicas(4 wheel steer thingy) & rear wheel drive
Thanks guys
So basicaly you shoud have a white 34GT-T with hicas.
If you 'decode' your model number (the GGKB...) it will tell you what options were fitted @ factory, do a search on SAU as memory tells me there are at least 2 threads covering decoding.
Chers bb
Edited by BundyBear
Chers bb
Thanks bb - so far so good... now i'm going to look up the model number :)
thanks Dark26, for some reason my mate's copy of FAST wouldn't accept the VIN, we'd been wondering whether it was an optioned up GTS or GTS-X lol
Hmm maybe its a different version? I'm not sure, anyways, no problem!
Hi,
was hoping someone could help me out with an ID on my GTR.
VIN is BNR32-002002 Model is KBNR32RXFSLMZG
I know the car was built in 1989, but i am unsure what the last four letters on the model code mean. (LMZG)
Hopefully someone can give me a heads up!
Thanks!
Edited by Outrun
Hi,
Thanks!
BNR32-002002
I did a search of this thread and according to pg 39;
L = Projector Headlights
M = Climate control + upgraded stereo
Z = Might be black interior trim
G = ABS and viscous LSD
Hopefully thats right.
hey i just bought a nissan stagea, can you please check it for me
WGNC34 - 138165
Thanks
WGNC34 - 138165
BNR32-002002
Thanks Heaps !
WGNC34 - 138165
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
