Also, can anyone lend their assurances that the FAST printout correlates with the compliance/build plate pictures of an R32 I'm looking to buy. Does that compliance plate indicate that it was imported in 2002? And FAST states a gun-metal build colour?
Guy
no one will give you assurances on what is stolen software, this is nissans internal program, and while fairly accurate it DOES contain SOME SMALL faults.
while FAST wiil give details on a cars options (paint color, ABS, A_LSD, etc) it is mainly for looking up part numbers, therefore should not be relied on souley
as for compliance plates, Blue = orig nissan plate (note the 6U9000 is missing..) green is the australian import plate
given FAST and nissans plate list the same paint color, I'd guess thats the original color
Car passed compliance 08/2002 (Green Plate) and therefore was imported before this date (usually only weeks B4 but could have been anytime)
cheers
im trying to get a full list of options which came on my car
could someone check
ECR33105178
please :happy:
Anf
sorry man only lists ABS and a lot of jap my pc cand handle
you might have betta luck HERE
cheers Bundy
Cheers mate, I understands what your saying, I probably should has used another world rather than "assured", I was merely looking to confirm I was using the software correctly. It could come in handy later if I end owning the car (provided the StateRoads inspection goes well :D), the fact that the plates and the read-out correlate is a bonus.
Hi guys, would you be able to check these 2 VIN numbers
1. 1995 R33 GTR V-Spec - 6U900BCNR33005989
2. R32 GTR - 6U9000BNR32002902
I am looking at purchasing either of these vehicles so I want to confirm they are both GTR's and what factory options the vehicles came with etc.
Cheers for the help!
Jace
Jace
There you go pal.
I remember finding a good page that had the meaning of all the codes. I will try and find it and post it up.
Here's the VIN # for the Midnight Purple R33 GTR V-Spec 1996.
6R91MPORTWH2R1001.
I know this seems like a strange VIN #, however where I work we record all VIN #'s, and this is what is on our records for an immaculate R33 GTR I'm considering buying. My assumption is that this VIN # was issued by South Australian Licensing Authorities (that's where it was imported to).
Would be appreciated if you could check it for me!
Cheers,
Jace.
Could i get this VIN number checked please - 6U9000BCNR33024253.
I gave you the Australian VIN number for this car in my last post, which you advised would not be recorded as it is not a genuine Nissan VIN.
The genuine Nissan VIN is BCNR33024253, however I placed "6U9000" before it.
Hopefully it is recorded on the fast software, and it should be a 1996 R33 GTR V-Spec Midnight Purple.
Cheers!
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
