yeah im in the same boat.. not in my system either. sorry dude.
btw whats up with the green plate?? i havn't seen one of those before. the numbers and details on it dont mean anything as far as nissan is concerned. im guessing it was a grey importer's work lol
As a thread "VIN's you want fasted" was pretty successful so I think we should restart it with some guidelines on what you can do to make it work:
1) Your VIN number is the Vehicle Identification Number from the Japanese factory. It contains your model number followed by the build number of you vehicle.
Examples:
- BNR32001000
- ECR33003928
- BNR34000897.......
When the car comes to australia the VIN number is prefixed with 6U9000 and you're Australian VIN number becomes 6U9000BNR32001000 (for example).
When posting VIN's all we need is the part of the VIN number after 6U9000.
2) The VIN number is found on the factory blue compliance plate.
3) The FAST program is no longer available for download anywhere as far as I know, is around 2.2gb so I can't just send it to you on MSN (sorry).
4) I do not work for Nissan (sorry again).
Hopefully someone can merge the threads or something....
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
