Can you please do these too? :)
WGNC34-136534
BNR32-014689
Is there any information on mounted options and if they are some special model?
Seller said the Stagea was Dayz edition and not sure if the Skyline is a genuine Nismo or just has all the parts fitted.
Cheers :)
i need some help to try an find out a little bit of info about my car NOTE THE BLUE NISSAN BUILD PLATE ON THE FIREWALL WAS REMOVED BEFORE I BOUGHT THE VEHICLE .i would like to know where and what work has been done to my car how many owners ect" the engine number is rb30117488a axle code :r11 vin:6h91mportwhf79096 can anybody help me out with abit of info about my car please ???
You'll need to track down the Nissan chassis number to run it through FAST. It should be physically stamped into the chassis somewhere. Newer Nissans have it on the right hand chassis rail near the RHF wheel. Not sure about older ones though. I'm not sure on the legalities of not having a manufacturers build plate attached to the car, but it might be worth looking into to save trouble down the line.
CHASSIS NO: BCNR33 000358
VIN: 6T91MPV97Y2BFX019
Engine No: RB26700733X
It's meant to be a 1995 R33 GTR V-SPEC silver colour.
See attached. Doesn't appear to be a V-Spec.
Edited by Psymon
Thanks for that!
I've just put a deposit down on the below car, so if you could please check this out for me that would be great:
VIN: 6U900BCNR33021482
CHASSIS NO: BCNR33 − 021482
MODEL: GGJPRWFR33ZZAAA—A
It's meant to be a 1996 R33 GTR-VSPEC with KR4 silver
1996
KR4
V-Spec
Hi all,
Could anyone please FAST this VIN for me.
ECR33-102498
Suppose to be '98 model in Wine Red (AR1).
Thanks in advance
Grant
96 model in AR1.
vin- BNR32003522
ENG- RB26021915A
MODEL - R3292A
ANY INFO WOULD BE GREAT THANKS.
WOULD BE GREAT TO FIND OUT THE REAL YEAR OF IT THANKS
November 1989.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
