hey guys,i've read this thread from page one to here.learnt alot bout the codes and alike.also learnt that after finally installing fast software,i have no idea how to get it up and running!!!thanks for this service you're doing,it's uber helpful.if anyone's bored,could they run this vin for me? BCNR042055.was also studying the serial number/build numbers,and aside from the ascending with date style,anyone know how they refer to build?wiki has prod numbers and the build numbers seem awfully high if they were simply just the number of the vehicle built,(did that make sense at all????)anyhows,big cheers in advance to you guys 'fasting' out there.:cheers:
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
