BNR32 013343
thanks in advance.
this will be interesting. the compliance plate that the aus government put on states as 8/93, which should be series 2.
dont have the brakes, has push clutch.
and the vin plate also has the 6U9... doesnt end with the factory vin.
I'm sitting here with the start of the flue today, so thought I'd reinstall fast (Haven't run it for years) and help out a few of these...
6U9000BNR32007072 - R32, made march 1990, color kh2, GT-R manual, model KBNR32RXFSLMZG
BNR32013343 - R32, made December 1990 (so definitely not 1993!), color kh2, GT-R manual, model KBNR32RXFSLMZG
6U900BCNR33004065 - R33 GTR/V, made March 1995, color LP2, model GGJPRWFR33ZDA-----
6U9000HNR32036867 - R32 GTS-4, manual 5 speed, rb20det engine, made may 1993, color 732, 4wd, model KRNR32RGFSLCA
DR30 036466 - R30 made sept 1983, color 060, and "F5" is coming up where the model normally is. I think the engine is FJ20T
Hope that helps everyone.. :-)
Edited by ian
thanks heaps ian.
yeah, sort of confirmed my suspicions...
at least now i know.
JN1WRGY60A0046947
Cheers jnr
I tried a few different combinations(it is entered in two fields ie BNR32013343 is "BNR32" and "013343") ie
JN1WRGY60A 0046947
JN1WRGY60 A0046947
WRGY60A 0046947
WRGY60 A0046947
And it can't find anything. And it isn't the build date either, as though my copy of fast is a bit old it has our feb 2001 stagea in it (Looking at the list it has I have data up to about July 2001) and it definitely goes back to the 80's...
So I'm not sure what I'm doing wrong....
Ian
Hi, just wondering what you could get from this:
Chassis No: ECR33-130626
Vehicle Identification Number: 6M9IMPORT12LV0029
Mostly interested in the build date, as its a series II '97 aparently.
Production date Feb 1997, KR4 color, HICAS, RWD, Manual 5 speed, model GGKBRTFR33VDA----A, and it's a GTS25T
- and I don't know how to bring up the 'options' page that a few other people have posted - can anyone tell me how to?
Ian
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
