g'day
can someone please do my GTR's VIN please - does 'GTR/V' mean V-spec ? as im wanting to know if my GTR is a genuine V-spec
BNR32309512
CHEERS
-EDIT SORRY FOR THE DOUBLE POST PLEASE DELETE THIS ONE, CHEERS
Edited by r32gtrv-spec
g'day
BNR32309512
CHEERS
too old for mine ( OCT11) one of the earlier guys may be able to help UNLESS you can give me the blue plate THEN I can tell you plenty about the car.
ok im still confused it doesnt tell me if its a V-SPEC or not??? it just says gt-r ???
WHAT info do you need off this 'blue plate' ?? are you talking about the blue plate on the firewall ??
cheers
cheers
Quote from Wikipedia
The V-Spec added Brembo brakes and a retuned ATTESA E-TS system to the Nismo and N1 packages, as well as 17" BBS wheels with 225/45/17 tires.
so there isnt any way to tell IF its a GENUINE V-SPEC or not ?? anyone can just chuck a set of brembo brakes and certain size tyres onto a GTR and call is a v-spec then ????
so whats the point of a v-spec or m-spec when you can make a mock up version and sell it as a 'genuine' v-spec ???
cheers
if it comes up as GT-R - that is standard GTR and NOT v-spec or above
cheers
their is tread on how to pick R32 GTR based on the VIN, you can solve this issue by looking it up.
R33/ R34 - the V-Spec and up actually had FAST showing it as GTR/V for V-Spec
Found this.
http://www.skylinesa...ost__p__5213163
And this.
http://www.gtr.co.uk/forum/19618-r32-v-spec-how-tell.html
Edited by H4x
Can I get the part number for RB20DET gear plug filler plug and and drain plug please ?
Thankyou!
Filler:
01642-00021-
Drain:
32103-U8400-
If you need to get the parts off a different car tell me what model the car is and I will say if its the same.
Can someone fast me this one
bnr32-016288
Build date and paint code?
Built : 05 / 91
Paint : KH2 - Gunmetal Grey Metallic
:cheers:Hooray for me !!! :merli:a party hat and a sparkler to celebrate.
Edited by Not a Pulsar
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
