No probs, Miguelone can probsly dig more details out if you need. He Knows Stuff. :ninja:
Haha nice, well i've already had the car for 2.5 months. Hasn't missed a beat *knock on wood*, Only thing i'm concerned about is that the km's might have been wound back.
Bought it with 85,000k's on the clock from an importer in Melbourne.
I'm paranoid that if it has been wound back my timing belt might never have been changed amongst other service things.
I think we all suspect dodgy kms but if it looks ok and goes ok then it's not a major issue but to be safe, praps it might be worth getting a pro to check it out and do it if need be. as in, belt kit, water pump and so on. Do all your own fluids and plugs if you can, Prevention and cure etc...
Yeah i've done all the fluids and plugs, Will be getting my regular mechanic to check out the belt kit and water pump + do a mini service for me.
Think i'm just paranoid.. but hard not to be when you read of so many horror stories.
snapback.pngsamuri, on 07 January 2013 - 06:43 AM, said:
could you check please.
stagea
vin 6u90000nm35310809
My FAST is too old for this ^^^
follow up >
So cna any body else help please?
Your car is an Autech model by the looks? Axis?
Ecu's changed unsure on diff tho, might justify that nismo one I've wanted
Dunno what R32s are like but my 33 sits on maybe 3000 rpm at 100kms in 5th. Have a search and see.
Diff =/= Final Drive.
Final drive ratios for All 32 GTST's manual or auto are the same as R33 Auto Ratio (4.3:1) Manual 33 GTST's run a 4:1:1 final drive ratio.
The differential bolts inside of the crownwheel(Parts of the final drive) and this gives you your LSD. When you buy a Nismo LSD kit you will not get a new final drive crown and pinion so your ratio will stay the same.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
