Cold region package is heated mirrors etc.
Hi (00)Skyline(00),
I think Miguelone is correct with the mirrors.
The car has heated seats too. I'll try to upload some pics but I'm a bit of a noob in that regard.
I see, it would defiantly come in handy for the winter.
Sounds good :)
Ok, so i have done a revs check on this car and its showing it was complied in 05/1990 and that its a vspec?
V spec were made 93?
Anyone know whats the deal here?
Yes, V-Spec's were made in 1993.
Post the Model Number and let me have a look.
It's the number starting with "KBNR32..." Under the Chassis Number on the blue plate.
BNR32-008320
KBNR32RXFSLTAA
Im not sure why its showing the compliance date as the build date also, through the revs check?
REVS is wrong.
Compliance Date can not equal the build date... That's impossible as it was built in 05 - 1990 and only just came to AUS.
Compliance Date usually refers to when the car was complied to AUS Standards / ADR Laws.
Your model number checks out to be a Base Model R32 GTR, made in 05 - May.
KBNR32RXFSLTAA - "X" signifies it is a GTR (16 Inch Wheels) = Base Model.
If the "X" was a "B" then it would = V-Spec (17 Inch Wheels)
On a side note: KBNR32RXFSLTAA, "L" = Fog Lights from factory... You have fog lights on the car?
Is this genuine V-Spec?
Vin-BNR32-302657 (Chassis No)
Model-KBNR32RBFS AA
These numbers are on the Blue Compliance plate from Japan I believe.
Thanks in advance.
Edited by glaze
BNR32-008320
KBNR32RXFSLTAA
Someone messed up when they did the registration. See it on imports a lot. Either build date is compliance date or compliance date is build date lol.
Model-KBNR32RBFS AA
Thanks in advance.
Anypne help me out with this? I have done some more research and I am 99% sure it is a VSpec, but just want it confirmed:) Thx
Model-KBNR32RBFS AA
Thanks in advance.
Vin- 6U9000BNR32302657
Eng-RB26 078615A
Yeah, the VIN and Model Number it checks out to be a V-Spec:
Sweet! Thx (00)SKYLINE(00). Put a deposit on this tonight and will have in my hands next weekend.
Sounds good, post some pics :)
Visibly you should be able to tell in stock form:
Brembo Front and Rear Calipers.
17 x 7 +20 or 17 x 8 +30 BBS Wheels (Check the centre of the wheels)
V-Spec Sticker on the boot lid.
A retuned ATTESA E-TS system but that you wouldn't be able to tell straight up.
It doesn't come with Rear Brembo's unfortunately or stock wheels. Will start the search for these ASAP;)
Interesting... So it's got stock Brembos on the front but not on the rears...
So what's on the rears? Just "Nissan" (Sumitomo) calipers?
  • 3 weeks later...
Can someone please check
BNR34-001021
Thanks in advance!
Is it possible to get late KV36 model checked which doesnt come up in FAST system. KV36-400752
Thanks in advance
I am getting mix of 5 results but all the listings say the build date is December 2008...
Thanks Mate,
Does it show what factory options it has and all like the FAST system or just the build date? Build date of Dec 2008 sounds right.
Edited by rawzz_v35
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
