May i have bnr32-017857 decoded?
Can't edit my post, i think the number is actually bnr32-047857, not 017857...
Both those numbers had complications.
Post a pic of you build plate and let us have a look.
Well that's the problem, it's not on my plate it's on the engine. I know my chassis is a 1993, i can still post a pic, but supposedly the stealership i bought it from here in Okinawa said it has a newer, but lower mileage engine in it, not the factory one (not sure what happened to it). So newer would mean to me 93+ model year engine. But i have reason to believe it's in fact NOT newer, so I'm a bit curious. I'll see if i can get better look at the numbers, had my wife look at it and she said it looks like the first number I posted, 017857. So i dunno.... :( Edited by Silverstreek
Well after further looking into both the VIN's you posted, they both came up as (July) 07 / 1991 models...
Wouldn't surprise me about the engine swap, it happens in Japan...
Still post a pic of the VIN's and lets have a look.
Also, do you have the VIN engraved on the firewall?
Yes i do and it matches the blue plate, so that's good. They informed me before and after I bought it, the info about the motor, so i knew it wasn't the original. But, like I said, they said it was "newer" AND "lower mileage". On the paperwork i got with the car it says "used engine ". So, I'm guessing if I tried to take it back and tell them i want my money back and to cram this car, I'd have no ground to stand on. Le sigh....
I see, thanks for that.
How many Km's has your GTR done (Speedo) VS the amount of Km's the "Used Engine" has done..?
Do you know if the timing belt has been changed?
Any stickers..?
Hi can someone please check, bnr32-309201
Thank you.
Kbnr32rxf7s aa
Thanks skyline.
Ok thanks!
The complications came up with a few results, one saying it was a Base Model and the other saying it's a V-Spec II.
But you Model Number confirms it to be a base model R32 GTR, built in March 1994.
Damn, can we go with the vspec II. :)
Thanks mate love you work.
I was checking cause I pulled motor out for rebuild and it has short nose crank so obviously not original motor.
:laugh:
It's just Brembo calipers that make the difference, along with a sticker and BBS Wheels for a V-Spec.
Not original engine or had the RB26 been modified from previous owner?
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
