Ok so I thought the engine number was on the plate which it is not. Is there something I'm missing.
Engine Number is usually on the side of the block.
Not on the Blue Plate... If that is what you are thinking..?
Yeah for some reason I thought the number would also be on the blue plate, and that would correlate with the block.
No, the blue plate will not have the engine number on it.
Unless you know for sure the engine you got in at the moment is from another GTR and have the build plate for that GTR too...
You'd assume it's just modified from the previous owner.
Thanks for your help mate.
Just so I got this straight the chassis number does not have an original engine number allocated to it.
Cheers
Correct.
Unless you can manage to find the paper work from the Nissan Dealer in Japan from where you GTR came from...
They might have a record... :laugh:
Correct.
Hahaha :)
and here I was concerned about not having matching original engine and chassis numbers.
I see, thanks for that.
How many Km's has your GTR done (Speedo) VS the amount of Km's the "Used Engine" has done..?
Do you know if the timing belt has been changed?
Any stickers..?
Odometer reads 147,xxx km. I have no idea how many km is on the used engine, I guess I could go by the stealership and ask, but those guys are either honestly dumb on the cars they sell or they play dumb to keep from having to be liable for anything. there is a sticker on the radiator fan shroud I believe, i'll snap a pic of it, but that's the only one I see (that's non-factory looking to me). as much shitty luck as I've had with this car, it wouldn't surprise me if it's not been changed, hell it might just be some bailing wire and duct tape under the damn cover for all I know. so many problems/surprises with this car...ugh.
how do you input the vin in FAST? I have a "friend" who has a copy of FAST and can't seem to figure out how to use certain features on it, like looking up VIN's. :D
I see, I guess depends on how far you want to take it with the dealership but I guess, just fix it up slowly, getting it back to how you want it.
Unless you got the time and money for a full rebuild, then you will know for sure it's all good.
http://www.nissanfast.info/carinfo.html
"Put your VIN code in the "VIN code" box in FAST" - As simple as that sounds :laugh:
Hey folks,
Can you run this one for me please:
6U9000ECR33103068
Cheers
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
