my timer shuts off if you touch anything like handbrake etc, have seen some you stall and they run ACC power after its stalled.
should be fine as long as both are under the tyre rule and you cant increase your track by more than 26mm (measure from centre line of tread to centre line of tread and check it against factory specs) so if you have a 17x8 20+ offset wheel standard and go to a 18x10 20+ offset, technically your track hasnt changed.
sorry i ment the pump keeps running after its stalled cos its still on acc power. at a place i used work a fella had a vl wagon turbo and it had a fuel cell and surge tank and external 044's etc but for whatever reason whoever did the pump install, the pumps would run all the time on acc power so he had to crank it almost immediately and when it stalled it would keep pumping fuel so he'd have to kill the turbo timer quickly because it would feed too much fuel too the rail and the fuel reg would struggle and it would over pressurise the fuel system (apparently).
just saying cos im sure theres afew cars out there that people have home job wired heavy gauge wiring to the fuel pump for full battery voltage and could still pump fuel after stalling?
sorry for off topic
Sorry, last relevant Q, doesn't the fuel pump normally keep running after a stall... if the car is in the on posit, the pump comes on and keeps the line pressurized, then stops once there is pressure. If there is a fuel leak, regardless of the turbo timer, the pump would keep pumping unless the ignition was turned off... but in the case of a turbo timer, the fuel pump would stay on after the ignition was turned off or until you shut the timer off also, so it is just one extra thing to turn off...
I know on this car and my previous car that hod no turbo, the pump will pressurise when the ignition is in ON, and then stops once there is pressure. If stall, the pressure is bulst, then the pump stops. If turn the ignition off normally all power is cut, but if have a turbo timer the power remains for the timers duration.
I may be missing something, or mine is just hooked up well, but there really appears no issue or real difference?
Sorry to clutter the thread, please feel free to PM me and explain better RS4-S.
when you turn the key to start the car the fuel pump gets a few secs of power to "prime" the fuel system ( you can hear a relay click when the pump shuts off). i dont think it will keep adding fuel til 'X' pressure is reached. most electronic fuel injected cars will need a signal from the ecu to say the car is running/cranking and allow the fuel pump to run constantly
So Ill make sure to have the standard wheels on the car next time im there and Not 10" + 15 on the back :P
Also with the above if you went from an 8" + 20 to a 10" + 20 then the track increases 25mm so just legal
nah its measured from centre tyre to centre tyre, if it were from outside edge yes that would be correct
  • 4 months later...
Dickson will pass you with a pod if affixed properly. I've put 3 cars through with pods...
If i still had my stock rims, would loan them, but they are gone.
Edited by J'son
Anyone with an R33 Series II have a rear seatbelt clasp I can borrow for rego... Everything is cleared except that mine for some reason had a centre one on one side so it doesn't clip in :( Need this asap! I will remove the seat, borrow the clasp and return it again straight after my inspection which will be tomorrow (if I can get the clasp tonight) or Tuesday at the latest. You will be doing me a MASSIVE favor :)
THIS IS NOT FOR A SKYLINE:
I need to borrow 4 rims and tires for a Mitsubishi Lancer. The ones that came with the car put the track off by 20mm, and also didnt have the right load rating (only 500kg not 530).
I borrowed a set off a mate of mine, but they didn't pass either, the rolling diameter was out... (They were 70s i need 65s).
This is what i am after, either to borrow stock MR lancer mags (most idea option but they must be the STOCK ones, and have the correct tire width and height), or else the specific ones on the tire placard:
185/65R14's with a load rating no less than 86 (530kg), and a speed rating of no less than H. The rim size is 5.5J.
Please get back to me asap if can help me out. THANKS!
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
