  • 4 weeks later...
Has anyone got a stock exhaust for an R32 GTS-T I can borrow. I have an inspection with dickson on Friday, so If I could pick up tomorrow night that would be fantastic.
I have a diff back exhaust that will pass Dickson. It will fit R32s with a 3" or 3.5" exhaust
Also i am looking for a set of R32 GTR wheels to borrow for Dickson
When is your inspection. I have a set of r33 gtr wheels, that will be getting new tyres soon. I'm borrowing a friends 34 gtt wheels.
Ill pm you regarding the exhaust.
Anyone able to lend me a compression tester that I can borrow?
Ok, i got one.
Cat back pipe with a peashooter, if you want to use it. Even got a stock downpipe if you need it.
And other things.....
  • 3 weeks later...
  • 1 month later...
Has any got some 18" Wheels to suit a GTR with 245/40 tyres that I could borrow for a rego inspection? I can lend you mine so your car is not unmovable?
I need new tyres but I wanna go 255, unfortunately my engineer cert is for 245s though
Anyone have an RB25 turbo I can borrow for a few days. Need to get mine sent for update to Hypergear. Just need it to install in car and drive it out of the shed whilst mine is going away. Will not drive more than 20m with your turbo.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
