Wow, so at the beggining of the Top Gear episode tonight I saw an ad for the Mazda 3 MPS, they claimed 190kw, so I thought I'd look it up.
http://www.mazda.com.au/mazda3mps/
Gotta say, everything about it looked good and its price is good also. It has a great stereo and great dash and really good features, but I had to read through almost every page to find out that its only FWD.
Now, what a waste. Everything seems so good, it has 380nm of torque.... But FWD? Give me a break... What kind of 'sports car' has that much power through the 2 front wheels?
Damn Mazda... what a let down.
C
https://www.sau.com.au/forums/topic/130248-mazda-3-mps-released/
Yeah me thinks I'd still prefer the XR5 to the MP3 thingy.... what ever you call it! My brother in-law has a XR5 and let em tell ya... they are great fun to drive... responsive... gutsy... and I think i'd prefer the Volvo power plant to the Mazda... but hey, that's just me. :happy:
My flatmate picked his up today, and they are a real scream. I'd take it over the XR5 any day - surprisingly it doesn't torque steer and handles exceptionally. It's just begging to be thrashed (the test car copped it) and the power keeps coming through the rev range.
I couldn't bring myself to sell the R34 for one though :(
There are only 2 mazdas I would ever think about getting....the RX7 (obviously), or if i just want something that cruisey, and wont get me hooked on modifying it, the MX-5 SE (dont know why, but I always liked the look of one - very much like a zippy little toy)
I have heard very good things about the 3 MPS.
Mazda unlike Holden have thought about the torque steer problems associated with high powered fwd cars and have a variable adjusting front diff to stop torque steer like the astra vrx.
Will be taking one for a test drive this weekend and pretending the g friend is going to upgrade her 2005 3 for 1 of these
Those that mentioned the MX5, hell yeah I'd have an mx5, what a cool little track car.
INASNT, yeah I might go and drive one too, then try to convince my wife to let me get rid of our N16 pulsar for one. :)
Astra isnt holdens fault hey.
Id still go the focus, I think it looks better. Really the focus and 3 should be the same car other than the engine as its all ford anyway.
And the alfa was a V6 for crying out loud, its nuts.
Either way I think all these cars could be quite dangerous. If you know how to drive them fine, otherwise look out. Guess its the same with everything tho.
I drove one a few weeks back to the workshop for a suspension engineering upgrade. It was raining in the morning and it was really weird, it doesn't torque steer because it cuts the power (traction control). So I tried to drag off my own Stagea (up to the speed limit) and got destroyed. It had like 10 fwkw, just kept cutting the power to stop the wheelspin. When I modulated the throttle it gots its traction control all in a twist.
It was the same on corner exit, give it a squirt to fire it away from the apex and it did the power cut thing. Waiting ....... waiting........OK lets go now.
If I had one, the traction control would have to go on day 1. Then it might be OK for me, but dangerous in the wrong hands. Power understeer city.
My verdict............needs 4wd.
:) cheers :)
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
