  • Replies 418
Posted Images
it's a pretty easy trip. just get onto the M5 and keep heading south. then take the Goulburn exit. There are better instructions on the wakefield park website. :yucky:
and hanyou, send a pm to N1GTR who'll have all the details for accomodation
there will probably be a group heading down together on the tuesday night that you can tag on the end of!!!
sweet az.. ive gta get a hicas lock bar (hicas playing up) & castor rods (bushes are split) still.. but meh if i dont get it done cant doo too much harm i guess.
ill have to come there on the day as i finish work at about 5:30 on tuesday.
As far as I'm aware this event is only timed if you can get someone with a stop-watch to time you. It's not an offical track day as such. But I'm hoping to get as many people timed as we can by people on the sidelines.
Leave the stop watches at home and just go have some fun. Fark lap times...they will drive you mad chasing them :(
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
