haha will do. Id recommend this guy to ANYONE hese fantastic. Kila bodyworks quoted me 550 excluding hifill and said it needs to be sandblasted. This guy hifilled and sprayed for 350
nice,,
wot sort of power you making i take it youve had it on a dyno :D
Yeh it's been on the dyno early this year & will be again soon - not HUGE power 430 ponnies at all 4. Comes on nice n' early, spooling from 2500rpm with twin R34 N1's, good response, meaty torque & nice top end at 23psi...
Edited by double overhead sun visors
nice for those that dont know 430HP > KW = 320
my mate has just modified his GTR and put twin HKS 2535 sumthing i forget sorrry and HKS adj. cam gears and hks cams sard 800cc inj. he makes 320kw @ rears and it falls over runs out of air so he needs new AFM's this was boosting @ 16psi
b4 he had these mods he was running 19psi and could do 0-200 in 12secs
My R33 Series 2 GTR V-Spec... with the old plates...
Colour is 'Sonic Silver' with c/f bits...+ everything mod'd
Awesome. Pretty sure I spotted it in Civic a few weeks ago, sounded, looked and went the way it should. Cool car.
couple of mine. getting Bannana bar from MAVRIC fitted in 2 weeks :(
Just some friendly advise :)
looks like the reo' needs to be lifted to support the bar a little better. Just loosen the 2 bolts at either end of the reo, angle it up more and fasten the bolts back up.
From the pics looks like there it too much gap btw the headlights and bar.
Hope it didn't offend you, just trying to be helpful.
primordial? have i posted pics before in here? lol oops soooo many pages i forgot if i did, sorry haha...
hehe nah no spammer :-)
ben...
ben, Love the car... Looks VERY nice.
Would hate to think of the $ that went into it. I have spent HEAPS on mine and still doesnt look very special.
Who does most of your work? (mechanical and interior/exterior)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
