Sweet wheels Nizmo freak, they look awesome!
I think you should get some side skirts to set it off - r33's need them badlly. Your car won't look so high when you get skirts. I love my skirts:)
Cheers mate, yea i plan on getting some stock skirts in the near future, im looking at getting some teins so hopefully the car wont be so high for much longer :cool:
this is mine
Hey Trust 33 Im sure ive seen you in yennora once, a while ago u came past saw me and drifted up a street near the station?? You had stockies in the back... Anyway i put some 32 gtr rims on but not entirely happy with the look might revert back to the black stockies what do you guys think?
Keep the R32 GTR wheels... looks hot better than stockies painted black I reckon :P
Edited by vietorious
Hey Guys, Heres a couple of my R33 at Wellington Point in Bris. Full bodykit to come. Can't choose one but. Don't want something as stand outish as veilside but more of a smooth clean look. Any ideas?
yeah it has been by the help of kyb suspension, but want to have the wheels tucked in the guards abit.
the car will be going from 300hp to 400hp shortly
400hp... that will surely put you in your seat :pirate:
what better place to post this for all the R33 owners :)
http://www.skylinesaustralia.com/forums/in...howtopic=175830
300km/h speedo kits boys...get on em :(
last chance too as once the cash is sent to amec, 20 kits will be produced unless more buyers have paid up before then....then more kits will be made!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
