Sam5709 - nice bonnet!!!
what ya run down the 1/4 mate!?!?
13th racer - dude, looks clean man! why wouldnt we be gentle!?!? (Oh, I know why! its got boost cruising in the photo!?!? lol j/k)
Charles89 - very neat! good ride for a P plater mate!
Cheers,
Chris
Hey fellas,
It was a nice day on the weekend so had the chance to take a few snaps - got some new 18" rims so yeah, here are some pics.
Edited by Spunky Munky
Thanks Trent04 and EvilWeevil - thanks for your comments. Yeah, I mounted my plates the way I did as I think it looks flush with the front grill - showing slightly upwards makes the front bar look longer. I'm going to dump my car further with some springs next weekend so hoping it will look lower and handle better.
AJ - both cars look clean - very nice.
I particularly like the Jun wing - not much people have them - would recommend you get those cars tinted.
Nice pics - gotta love Apollo bay.
Cheers.
yeh i wanna get them tinted but i dunno where to go and for wat price
is that wat the wing on my car is called?? the big one? i hate it i want the same as the other car the drift wing, just trying to find a cheap one
Edited by *AJ*
There's many places you can get it tinted mate - but I personally recommended tintprefessor.com.au - they're actually pretty good, you'll be up for around $450.00 from my memory.
Yeah, that wing is called a "Jun" wing - it's pretty good, not much people have it. Up to you, but I think the drift wing is not as nice.
i just dont like it as u cant see crap out the back window and cant tell if its a cop car ehind me at night or not lol
Tintprofessor is $265...
but the quality of their work varies greatly.. from crap to acceptable
fk off getting tint done for $450. join up to sauvic and go thru the supporting traders/sponsors list. look for a guy called brett. does a top notch job and is a helluva lot cheaper than tintprofessor. hard guy to get a hold of though. with your membership fee ($70) included you are looking at around $220
sweet as i just payed my membership the other day:D
