this be mine
That right there is my dream car (well, not dream, but it's the next car I'm going to buy). Silver, turbo, and with a sunroof (not essential). Awesome rims too man, I'd get ones with slightly slimmer spokes, but they're still nice. Whack a front bar on that, and a GTR wing and it's perfect.
^^ cheers man, i got the clear indicators alrdy, just being lazy and havent put em in yet, might even change the front ones to clear too
it's carbon fibre, but not 100%, dont think they are legal haha
can see it more clearly here
Well finally got my car lowered.....
heres a preview :)
Am getting better photos.....coming soon
looks much better without all the lickies and the P-plate!
Looks ace.
If you fitted spacers behind the 34gtr rims, it will push the rims out, closer to the gaurd, making the rims look bigger and the car lower :) Would slao look tougher :action-smiley-069:
Trentgtr - that looks sweet as now its lowered..
Z-Tuned - i want your bonnet lol where did you get it from? im looking at carmate, but yeh just need some other places to compare too
i got it off a private seller, every now and then one pops up for sale. maybe try ringing around though
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
