hmm I think its just dark colours in general, they pretty much all suck
If I could get another R33 GTR it would be in either white or silver, those two colours are the best and much easier to keep clean. My R32 was in metallic spark silver and never looked dirty..
Yet I still find something appealing about midnight purple
I wish mine was midnight purple..
If you end up getting a respray a nice midnight purple pearl would look good, a lot of the time the midnight purple color looks like a pearl anyway.
Yer i hear that!
Not a fan of white but if i had my time over again id get silver for sure!!
But yer there was just something about the midnight purple when i checked it out that i couldnt pass up...
Maybe its like one of those things where you see other peoples midnight purple GTR's and they look awesome but once you get your own one you just get over it..
I don't know but I want silver again, I am tempted to paint my GTR silver but I CBF prepping the thing
It's tempting man because the colour isn't far off what it is now but CBF really, I think I want to go with a lighter colour
if u go respray and wanna keep that sorta colour, go hsv's version of purple. HOT
pics a repost of my mates gtr but just to show the colour
That's not a bad colour, looks great in the sunlight
I thought the pics I posted (post #1460) turned out pretty good for midnight purple (just had it resprayed). Personally I love the colour and when I get my new car its going to be a Midnight Purple III R34 GTR, although sadly this isn't happening any time soon.
that is the first time i have ever seen one, was trying to find out what they looked like ages ago and could not find one, every pic i found had an mspec one so i assumed that the mspec was standard on a gtst.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
