Thanx a lot Basti ^_^ I'm just after hub centers for the rims now. Not center caps as the R34 center caps look lame. But caps that will sit in the hub gap. Oh and a V grill for the front like \____/
I have a grill to fit S1 and S1.5, check SA for sale thread.
Some bloody nice GTSt's in here. The standard has lifted and there's less of the big body kitted 33's I hate lookng at :nyaanyaa:
R33 2500R GT-X 1
PROMOTING: R33 GT-R RACING AT LE MANS 24HR 1995/96
... here is a few more photos of my R33 SKYLINE ... along with a few of the project documents from 1994/95 that i have been asked to post ... it has been in storage for the past 18 months up until a few weeks ago ... i will be attending the upcoming Skylines Australia Show & Shine in December to celebrate the 20th Anniversary of the R32 GT-R & look forward to catching up with some familiar faces that i haven't seen for a while ... :) ... ever since the car made its controversial appearance in these forums 2 years ago i have had constant correspondence from one gentleman keen to purchase it ...
... i have had it now nearly 8 years and cannot yet part with it ... :) ...
... sorry its NOT FOR SALE ... :O ...
... see you at the Show & Shine ... cheers malcolm ... :) ...
Edited by malcolm
seeing malcoms 33 reminded me of mt GTR, so i pulled it out of storage and gave it a quick hose and chamois, its for sale if anyones interested.
... WOW !! ... i can see how IMMACULATE that is !! ... very nice ... indeed !! ... :blink: ...
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
