Just stuff from hspo and hsv, delivered hsv stuff Monday and a transmission Tuesday.
ohk kool az if ya eva see a guy with strechers in his ear say hello lol that will be me
were abouts ya live
Its a hot lookin 33 damage but whats with the stoopid lookin wheel barrow handles stickin out the arse. :whistling:
they are for the haters like yourself to bang your shins on in carparks :(
nice vids damage keeps the good work up
why shank yew
bahaha
how you get away with that exhaust as it is? or you dont take it out much?
with very selective driving haha, been pulled over several times and never had a comment about em :blush:
  • Like 1
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
