Got some fitment issues up the front. 20 * 8.5 +25 rims.
The wheel is physically too large in rolling diameter and is rubbing on the top suspension arm. So I need to hit the drawing board.
Anyway the test fit...
What are you guys thinking? Improvement or not? I am going to slam the car back to the ground with the new rims, remove the wing, and try and line up a carbon fibre duck wing and roof spoiler.
I think the new rims need a new look...
yea they look hotttt,
slam to the ground, get the duck lip if you want, but i dont know about the roof spoiler i dont really like the look of them
but definently make these rims fit and slam the car to the ground :D
what size tyre on the front?
i like it but i dont know how you'll get around the front lip been a mile from the road purely because of the size of the rim you wont be able to reduce it much.
still nice wheels an all.
ROOF SPOILERS ARE FKN AWESOME.
Yeh im worried this suspension arm might be the death of me!
I took some pics to show it. Hopefully with a 5mm spacer on the front and a stretch say, 215/30/20 on the front. But turning still might pose problems, and I think full lock is out of the question lol.
But I mean come on bulk people have fitted 20s before to 33's (all be it chromies :(), surely there is an easy solution. Aftermarket suspension arm (thats less bulky)?
Oh and the tire on the front atm is a 245/35/20 I think. I wont go that wide on the front with the new tire, which will save me some space... but the new tire will have tread aswell (where thisone is down to the wire), so i fear it will even itself out abit there!
The Cannon Exhaust is about to go though. Looking to cut the tip off and weld something a bit quieter on the end to try and get a crisper less droney note
cool lower lip on the bar man, wheres that from?? accentuates the front even more than normal...which im starting to love :)
Just Jap. Took a lil bit of trimming and adding to fit. Otherwise it aint too bad. Just replaces the factory lip. Gives it more of a sporty look to the front without looking over the top whilst keeping the strength and fit of the factory frontbar.
Luke
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
