I used to want one of those 40th anni front bars, then i saw one on a car and didn't like i, now I'm starting to like it again. Maybe I should cop one and just keep my standard S2 bar for if I feel like a change :P
Thankyou
nah, LM's come with the standard rims. these were put on by the original owner. Its a bit lower now as well
what do you mean by 3's
Sorry was in a rush, LMGT3 rims. I've never seen them in all gold like that, they look good.
I have white LMGT2's which aren't as common as the grey ones.
they are Nismo Rays LMGT1's, 18*10 powder coated bronze. originally white
^^^^^ is that a genuine GTR front bar? Hence making in "pull in" at the sides on stock guards?
Hey Grant. No not a genuine GTR bar - fibreglass copy but I think looking at the width.it was made to the same dimensions as the GTR bar. Once the bar is completely destroyed, I'm looking at getting the Series 2 stock bar and a viva garage lip. I posted in your build thread on JDMST about it - loving your 33 by the way. :)
GOOD STUFF ADAM :thumbsup: looks amazing..i have the same skirts n similar front lip edge (from this angle at least)
specs on the wheels?? rim size? offset? tyres?
thanks mate
Cheers mate! I've got top secret sideskirts and a mangled trust front bar at the moment.
Specs on the wheels are:
Koya Drift teks
17x8 +34 with a 30mm spacer and 20mm extended LCA on a 215/45/17 -4.5 camber
17x9 +30 something on a 245/45/17 -1.5 camber
Hi Buddy, saw you at the lights trying to get in to the entrance of the carpark that the eomm was being held at. Very nice 33!
Cheers bud! I saw yours roll in, looks good!
mmm, your username looks familiar, ever own an MX5?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
