Cheers mate! I've got top secret sideskirts and a mangled trust front bar at the moment.
Specs on the wheels are:
Koya Drift teks
17x8 +34 with a 30mm spacer and 20mm extended LCA on a 215/45/17 -4.5 camber
17x9 +30 something on a 245/45/17 -1.5 camber
Cheers bud! I saw yours roll in, looks good!
mmm, your username looks familiar, ever own an MX5?
I didn't know you know John Ha and his green jellybean! He just mentioned yesterday that he was in the car with you. :)
Yeah I used to own a white mx5 which I sold before getting the skyline. Miss the little thing sometimes but the 33 is heaps more comfortable! Didn't you have a stagea at one stage Adam? And I definitely loved ur roadster as well dude. Seems like all the cars you've had have been modified very well. Big thumbs up to you!
hahah I've known Johnny for years! I recently moved down the road from him too haha.
Yeah I've still got the Stagea, no interest in anyone buying it and it's a damn practical car so I'm just going to keep it and do a few things to it. I miss my MX-5 too, but I love the Skyline in another way, it's wierd. I don't think I'll be letting this one go anytime soon.
Cheers dude! :D
Cheers dude! :D
Adam, I saw your car on Sunday at the JDMST meet, but didn't know who you were to pick out and come and say hello, and there were soooo many people there, so asking everyone would have been futile, as you could imagine...
they are Nismo Rays LMGT1's, 18*10 powder coated bronze. originally white
Ok, that's it: Car is coming out of the garage this weekend to show off the white LM GT3's :P
Not gonna wash the thing though. Bugger it. If I do, I'll pull the rims off and clean them one at a time.
Thanks mate, the wheels are drift teks 18x8.5+34 up front & 18x9.5 +35 or 18 (i'll have a look & confirm it for you ) on the rear
Just by liking at them I would definitely say they are +35 at the rear :)
is the paint Ford bionic blue?
Semi-as promised: Car didn't leave the garage, but I did take a few quick snaps: This thing is quite dark in the shade but is VERY vibrant in the sun. Minus the peeling clear coat near the boot, unfortunately.
My newish 33 :)
looks similar to mine :) had it 3 yrs, done over 50 thou km's. good times :thumbsup:.
cleaned and polished and wax etc etc etc today....its been far too long since its had a good scrub and shine what a freaking mission......that front bar is hell to get properly clean :blink:
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
