Best time of 12.7 @ 120mph 2.5 60ft. Wanted to see how it would go time wise as I drive it everyday . Cheap 235s stretched on 9.5 was never going to be great, but they worked ok.
Next time out late July will go some drag radials and aim for an 11
And yes its a rear diffuser
Cheers guys
Josh
Looks great.
Would love to know the spec's of the wheels and whether you getting any rubbing over humps, around corners, on full lock.
Any other pic's we can drool over :w00t: plz.
thanks for the rap guys...:)
it feels good when you get positive feed back
As for the wheel spec im runnning 19x10.5 rims wrapped in 265/30s all round with 25mm spacers, and to be honest looks good but havnt drove the car yet like that as im waiting to put my surge tank back in.. lol so havnt drove it yet just moved it into the middle of my garage, and yes does rub a lil on full lock... so looks good for shows like that but when i want to drive it hard il have to lift it a lil :)
and as for more pics once shes up and running ill give her a wash and take some decent pics
thanks guys
Jayson
one of my favourite r33's. if i ever bought silver, thats what i'd want it to look like.
Thanks mate! Jack did all the hard work. I have known the car since my first R33 GTR and so when it came up for sale I had to get it.
Cheers guys
Josh
thats still a decent time how much power you running..??
I think im the only guy here who still prefers 17s with chunky sidewalls..just looks more racecarish, .
..but I must admit on streeters the 18s like you have do sit better..what are they 18x9.5 +22
nice. love the clean enginebay :thumbsup:
sometimes i wish i'd bought a black one.....mmmm shiney
Yeahhhh Shiny.... for about a day then its all sharply downhill from there :P
Nah wouldn't trade it for anything, black is a love hate relationship but it just looks so damn good when its clean. keen to respray my engine bay then it will look alot better
18x10.5 +15 with 285/35/18 RS3s. Needs a touch more low and my eyes still need to adjust to blue after seeing the white so long. Car is moving to Okinawa, Japan in September. So a fair bit close to you guys down under. Most likely will be repainted after arriving there.. Everything must come to an end I guess. Also going with a big single setup, 1000cc injectors.. blah blah blah.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
