Is that docking lol
f**kin love the front, granthem , did you have to cut up the front lip for it to fit ? Also did you use "liquid nails" to attach it?
Only had to trim the Lip ever so slightly because of the cooler. I was fairly impressed with the rest of the fit. No liquid nails needed, it fits so snug that it wouldn't need anything to keep it on! That said I did put 2 small screws in the wheel arches just to be safe.
Took a while to track down the kouki 4 door parts tho...
Grant, car's still looking good as always. And Nick, loving the awesome action shots of your GTR! That's definitely where a GTR belongs - on track.
Here's a recent photo of my car (the white one) and RBScreamer's freshly sprayed R33 in a custom shade of dark pink:
I love the aggressive fitment! What front lip are you running? Also diggin the pink one! GTS-t's represent!!!!
Is it a genuine lip or a Viva Garage copy?
Why does everyone buy Vivagarage, Genuine is nearly the same price before shipping. It doesn't have the same non roundy bits either.
I needed mine ASAP for a wedding. Couldn't wait 6 weeks plus for delivery so I bit the bullet.
The Viva quality is alot better then I expected. Required no trimming to fit the bar at all (like I said, only the cooler). That said I would have gone genuine through Jesse Streeter or someone if I had the time.
Who made the original in Jappo land anyway?
Edited by Granthem
Flat black on white, don't think it would work..white is easy enough to do with a spray can anyway and still look good..
Though dark charcoal or gunmetal grey does work well with white..
I'm wondering what satin black would look like against my gunmetal grey. :unsure:
Genuine gear is really strange. I like to think of japanese workmanship being pretty good, but even with big name companies it can be hit and miss.
I know a mate who got (from memory) Dmax carbon roof wing, rear lip etc for his S15. The roof wing is the worst for finish, fitment I have ever seen. Overall it is disgustingly bad and was purchased through a reputable shop as a genuine dealer I believe. That said, the lip was good.
That alone sometimes scares me from spending oodles on legit stuff I've never seen in the flesh.
here is a couple pics of how my interior has now turned out.
originally had r34 gtr front seats and r34 gtr steering wheel.
Now has Bride seats, door trims front and rear and momo race wheel with D1 carbon quick release hub
I built my own bolt in half cage seeing as i have the skills and equipment available at work (basically work payed me to build my cage seeing it was done during work hours)
i also got rid of the sound deadening in the back seat and sprayed the rear black
I have removed the climate controll, all audio gear and the factory centre gauges. made my own parcel shelf to cover all the holes left by speakers
fitted up igniton kill switch and other switches which still need to be hooked up
also fitted four gauges to the centre console
cage fab
cage paint
carbon centre pannel
gauges fitted
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
