What size and offset are your rims on the gtst mate?
They were 18x9 +20 front and 18x10 +5 on the rear. Front and rear guards were standard all I did for the rears was roll the lip flat with the guard (not pumped at all) just to allow a tiny bit of suspension travel and that was it. Fronts actually had a 5mm spacer from memory
Edited by Weapon
A few quick pics of my 33. Also a video of my new varex exhaust for anyone interested.
Its almost complete in my eyes. It is stock height, stock wheels but I like it. I feel a lot more safe from police in this form.
As soon as my mate gets back from a week away, my new cat is being put in and some gauges wired up. All it needs now I think is a bit of a tune up. Only problem I have with the car really is the return to idle, it sometimes lopes as seen in the video but fortunately doesnt stall. Strangely it is a tiny bit laggier since installing the varex. A smaller air filter was installed at the same time. Will have to see which one is causing the problem.
Edited by Bennis
so gave the car a clean and had a play with the camera. the one thing i struggle with is framing a shot, so i drove around until i found a reasonably good place for photos. here are a couple of shots i took:
these were all taken using my 50mm SMC Super Takumar lens
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
