She is holding up alright terry. She just had her 19th birthday on original paint. But it wont last forever :(
Haha, you know how many hours this car took from me polishing it to get it to this standard. I would say 36 hours. Thats too much. But Im anal.
Waxed it properly for the first time in 1.5 years. Used the finest wax I could find, aka Turtlewax @ $12 a bottle :woot: Needs a good machine buff but ehhhhh
Man those rims really do suit the car!
I never thought white rims on a silver car would look so good.
Looks like you got some good fitment on them as well.
My guess would be 18x9.5 +22? or +20
  • Like 1
White wheels look fantastic on most colours and show off the wheels really well, but most people just paint them black and then you can't see them anymore. But it is fashion and you need to follow fashion
Silver on black, silver on gunmetal grey, silver on white are cool
I like black on black as well but can't see as much wheel detail but nice brakes stand out. White cars with white or black wheels are cool. White suits everything I reckon, even on red cars
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
