Someone told me they know of one to suit skyline.... thats the one im looking for.
Not much help but they do make em.
http://www.difftechnics.com.au/gto_nine_irs.html
Were any XE or XF Falcons IRS?
why would you want to do that?
if you want a diff wich is much stronger just use a z32 tt diff.
r220. 220mm vs 9 inch 228mm.
it will bolt up using gts4 driveshafts and WONT BREAK. not sure about the axels but.
how much power are you running?
r200 diff's and r32 driveshafts/tailshafts have a reputation for handling as much power as you can throw at it.... 9 inch conversions are very uncommon because the stock diff is strong enough...
Stuart's car will make a shitload more power and torque than my car and I explode CV's and snap axles 2 at a time with 265kW.
R33 GTST R200 LSD's and std axles = Rubbish in my opinion. The only reason people say they're 'strong enough' is because 99.9999999% of Skyline drivers ESPECIALLY the ones with big HP cars NEVER race their cars hard. They're all soft - especially the GTR drivers :D
Adrian
Hmmm.... Z32 R220 with standard gts4 axels or braced 9" with billet axles.
Tough decisions...
Adrian
oh, im sorry. lets see. a diff that bolts up.? or a bulky 1950's based bigger is better truck diff? not that theres anything wrong with them. just try finding one that has a nodular iron case and doesnt use a floating inner axle design.
il choose the r220 and perhaps using shortened r33gtr 31spline axles. hks and pretty much any other 1000hp drag gtr seems to do ok
worst case just get some "billit axles made to suit the diff that fits? or you could try and cut n shut a 9 inch.
dave
but... if you were seriouse you could probably convert the car to a 4 link set up. that would work best. and the nine inch will be very well suited
It's got nothing to do with being serious or not. It comes down to what you can do in the class you want to race in.
Thanks for all the info guys, i am running the car in Oz so 4 link is out and dont have spare 10k to throw at it. I have the R32 GTR diff and shafts fitted, sound like they may be up to it, ill just put a mechanical centre in once i know what gear ratio i want. TRPs R32 skyline has given me some faith.
TRP's R32 ran mid 9's off transbrake with an s15 centre and gtr driveshafts, don't know how much faster you want to go.
Wise move Stewie...no point trying to re-invent the wheel
R33 GTST R200 LSD's and std axles = Rubbish in my opinion. The only reason people say they're 'strong enough' is because 99.9999999% of Skyline drivers ESPECIALLY the ones with big HP cars NEVER race their cars hard. They're all soft - especially the GTR drivers :)
Adrian
Adrian, what do you mean by race hard??
thanks :P
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
