Searched and found nothing.
What turbo does a R33 GTST run stock?
Wanting to know as a m8 is lookin to buy same/better turbo as his has shit itself.
Jon
I thought they ran a version of the Garret T28 ... possibly... If I am wrong hopefully it will outrage an R33 owner sufficiently to post the correct answer to your question.
no R33 owner outrage here, but an R32 owner :O
its really hard to say what its 'the same as', due to the fact that i believe the turbo was specced especially for the RB25...
hopefully some of the more knowledgeable members find this thread and share their wisdom!
i thought that was the s15s?
r33 turbo is the same size whether its series 1 or 2. the series 2 just has a nylon compressor wheel.
or are you reffering to the series 2 being the r34 motor? which does have a slightly bigger turbo than a r33.
Edited by mad082
Yeah, I have been trying to find out for defeinite what turbo my S2 '25T has in it. I have heard people say that they have the nylon compressor wheel etc.. Is this true for sure? If so is this a bad thing, and should I be careful running more boost through it... that 2530 is beginning to look very nice ;-)
Cool, thanks for that mate - I reckon ill do supporting mods before I start trying to blow my turbo anyways...
Does anyone know what brand/type the stock turbo in an S2 R33 gtst or is it just generic nissan>?
Sorry about all the noob questions, but I am trying to build the rig into a very fast reliable touring car as opposed to making it a 10 second bullet.
Cheers,
Chris
So I guess id be correct in saying it will maek a really good sinker for fishing... What do ya reckon about 2530 or 2540 HKS turbos? From what I hear ppl r having good performance while still maintaining economy with these units.
I can see this becomming quite expensive~!
Its some mongrel nissan/hitachi/garrett T3 flanged thing.
But definately not
Definately is. pulled the turbo off of a wrecked 2000 S15 Silvia 5 weeks ago and its IDENTICAL to the turbo on my Series 2 R33 RB25DET. not tryin to start shit just throwin in my 2 cents.
