I haven’t been on this site for ages - can’t remember my old login so I signed up again!
Anyway, the Massive Skyline Cruise. I went with a friend last year and had a great day.
When is the next one? Oct or Nov? Has the club set a date yet?
Do you have to be a member of the club?
does the club have a calendar 'what's on', kind of thing?
I work most weekends so I’ll need to request the time off well in advance
https://www.sau.com.au/forums/topic/131105-massive-skyline-cruise/
  • Replies 110
MSC is in November usually...
The whole forum and all skylines in general are invited the more the better...
The events details will be posted about 4-5 weeks out from the event and this event will be stickied when its posted...
MSC has never been a club event.
It has previously been organised by Nismogirl and friends.
Erin (Nismogirl) has conveyed she will not be organising this anymore :) .
Yes we will have a massive skyline cruise soon.
But it will not be called MSC.
Who will be organising this one? Happy to help out if I can!
What will it be called this year? Why are we changing what its called?? GSC?? Giant Skylines Cruise?
why do we have to change it? no offence to Erin, but she never had a copyright on it or anything. i'm sure she wouldn't mind it for SAu QLD to carry on the tradition she started. it's obvious from finn34 starting this thread that people know it as the Massive Skyline Cruise and that's what it will always be
Dont underestimate your self Shane one man can make a Difference.
If you build it they will come!!!!
Seriously are you Skyline owners gonna actually gonna organise this. And come up with an AWSOME name for it.
That's great about people remembering it, but Erin has advised the current SAU Executive that she would prefer if we came up with our own name for it.
Yeah, not in those exact words, but Erin wants us to come up with our own name.
If you disagree I suggest you PM Erin expressing that you'd like "Massive Skyline Cruise" to continue on forever.
She may have a change of heart if she sees that so many people want it to continue ???
wow, I thought I was asking a simple question...
I didn’t realise someone ‘owned’ the cruise. How crazy is that! lol
And here I was thinking it was the ‘Skyline Community’ getting together.
Erin and friends keeping the name… Sounds a bit ‘us and them’
Is Erin still active here? no comment from her yet… strange? or maybe not.
Jake – there is a ‘Nissan Cruise’ run by someone at Brisbane Cruising, we may get into copyright trouble with them :)
Moving on and UP, I hope new cruise grows in strength and is bigger and better than ever.
1 suggestion, when the NEW cruise is posted, please use some reference to the old MSC, this way occasional visitors to the forum will be able to join in the fun.
Good luck with finding a new name – New Massive Skyline Cruise (NMSC)
This topic is a bit like beating your head against a wall...
I personally believe it should still be call "Mass Skyline Cruise". Because this year is number 5 so its a bit of a milestone.
I wish Erin would take an active part in the planning of this event as it was her baby to begin with, but she no longer wants to. So i say hand over the torch to the current events orginiser (MUD)...
Just my personal opinion (not as a moderator or as a club member) just my personal opinion.
I can understand that Erin has put a lot of time and effort in to the past events, and deserves recognition for that, but what i want to know is why, we, as the skyline community should change the name of OUR annual event. She organised it but it was the skylines attending it that gave it recognition. But in the end if she wishes to hold on to it there is not much we can do.
So a rename poll? Massive RB Cruise? perhaps not.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
