  • Replies 668
Posted Images
personal grudge... personal grudge...
you know what i hate....
socks
when the elastic around your ankles are really stretched and when you walk they curl into your shoes... :P
i think its time to invest in some new socks
Two words: "Thorlos" & "Lightfeet". Come and talk to the Guru about socks when you feel ready....
lol i thought that was gonna say "when you feel worthy" :D
well if your headed to street scene on sunday ill most probably see you there :D
nothin gets a convo started like loose elastic socks!... :ermm:
They fight the damaging effects of gravity
hmmm, i know someone who died from gravity. is it contageous? :P
its not the gravity thats a problem, its the life of the elastic that gets me... damn woolies socks. although this gravity poisoning has me worried...
your grandma wouldnt have any more of these gravity fighting socks would she? ordering online for a pair of socks seems abit extreme...
P.S. i dont want used ones!!! :P
Edited by SKYLVIA
A ACTLUDA is a new member to the forum who is using it to stalk and harrass someone who does not want any thing to do with them!
Must be that bad batch of eccies!! :)
I feel like I'm reading a book with every second and third page missing. (But now at least I know that Jason is a bad man).
Another thing that pis*es me off:cheap sh*t tyres fitted to performance cars like BMW's revered M3...such as the Nankang bottom-shelf units fitted to the beast I saw going over Hindmarsh Drive tonight. If you have the coin to peddle a serious sports car,put some money into it's boots,as they're the only thing between the car,the road and a BIG prang when the going gets tough...
What really ticks me of is people who sign up to forums just because someone who is ignoring them as they don't want anything to do with the just to harrass them ACTLUDA this is a public forum for discussions not for harrassment ok Jason (ACTLUDA) :laugh::) Now either use it properly or Get off it and take you prelude else where Stop Harrassing this person
See Beau ^^^^^^^^Jason
PS Wasn't Jason the main man in Halloween or Friday 13th?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
