hey guys,
just wondering when u get a wheel alignment, is there anything they should do with the hicas when they align it??
thanx 85URK
They should leave the car running while doing it!
bunch of comedians arent we, thanx anyway, i think i know what the problem is, when i had a wheel alignment just recently... apparently that doesnt include balancing of the 4 wheels, so they only did the 2 reear tyres they replaced... pretty f**kin stupid if u ask me, i wanted them to do the balance aswell but i though it was all included in the alignment.....
yeah balancing is a seperate service, really it should only need to be done when you put a tyre on a rim, unless you loose a weight it should not really change in the life of the tyre....
I wish. my last set of firestones were so crappily made that the balance was done 3 times over thier short life span, When I asked them why they told me they were crap and had the same problem with other owners of these tyres. I have Yokohama R1s now much happier.
if the tyre wears evenly, the balance won't change. but this is rarely the case...
balancing and alignment are separate things. It shouldn't cost you much to take the car back and get the front wheels balanced, should only be $10 or so per wheel.
or just go back and argue with them. Say, cmon, you got a full wheel alignment done and 2 new tyres farkin balance the fronts! it will take them 10 minutes...
hey all first things first you are supposed to get your tyres rotated and balanced every ten thousand km's and a wheel alignment too and if you over inflate your tyres will wear in the middle if you ander inflate they will wear on the outside if you don't rotate enough they will start to heel and toe which in other words parts of the tread will lift and they will make a howling noise and you should be carerful where you take it to get wheel aligned some people are dodgey remember if you have too much neg camber your tyres will wear on the inside and yeah you should get a print out when you get it done saying what the specs are and what settings you had and what they are now just watch out some places do rip you off too
well for starters i can rotate my rims bcoz of the fronts being a 235 and the rear being a 255 also they are directional tyres so can even swap sides. they re balanced the front wheels for me, which were taken off at another tyres shop to remove grass from and off i had. which he did not do a balance for me when they were put back on bcoz i told him not to, so iwhen i got new tyres i would get them all done at once (thinking it was included in the wheelalignmet) silly me. also one of the weights was missing off the front wheel. so that was the shudder in could feel. its all good now they fixed it all for $10.
  • 2 months later...
The thread ive been looking for! so all i have to do is drive my car on the 4 post set the steering wheel straight and adjust everything to specs?
does anybody have the specs incase its not on my work wheel aligner?
  • 3 weeks later...
Just want to add to this becuase i need to get my r33 aligned but they dont have that car listed in their system...which car do i tell them to use?? :P
  • 4 months later...
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
