Hi guys, I'm shopping for an upgrade to my alarm/immobiliser system from the one that was installed on my car when I bought it & would appreciate a few opinions of different places & systems people have had put in their car.
As far as places are concerned:
Strathfield is OUT, crap alarms & installation
Tonkins I'm doubtfull is much better & same goes for AutoBahn.
Complete Audio is only mediocre (Had my stereo system fitted there, not impressed)
I have also looked at:
Adelaide Pro Sound (Seems like a good installer)
autowatch systems
Tisonics (Not quite as sure about the install, but the product does look good)
Own brand
Ming (Don't seem too concerned about the customer)
steal stopper
Opinions for other places as well as these would be greatly appreciated.
Cheers
Edited by JazzaR33
https://www.sau.com.au/forums/topic/131617-top-alarms-installers/
  • Replies 40
i got my special alarm from interstate, then got a private guy here 2 install it. he was real good,knows all about them, and the alarm blew up so i went bk 2 him n he repaired it at no extra cost.
JOHN - 0405 702 292, tell him vange with the white line gave u his number. he should rem me.
he also would be able to tell u and get u the alarm u need or he suggests.
I second george @ adelaide pro sound. My alarm was a massive install... george, the team at aps made sure that everything was in working order, they spent the entire weekend on it and didn't charge an arm and a leg. Even got some interstate support in the form of chris rodger's the r34 specialist to finish off the remote start...
I've only got great words about george... tell them andy (that's me) sent you :D
I got a friend to install my alarm for me. very well installed. You have your choice of where to hide your alarm unit. Didn't spend a fortune.... or at least cheaper than Adelaide Pro Sound I should say ;). (can use the extra money to get other modules for alarm).
PM me if you are interested.
Thanks for the info so far guys.
Did like what I saw with george & his systems, biggest thing for me is as soon as you want to option up the autowatch system the dollars start stacking up big time.
Will look into the others too, but still keep him in mind.
I supplied my ebay car alarm to Graham West Workshops, and they called a bloke in. Was pretty cheap, think around $220 to wire up the full black-wired car alarm, the electronic boost controller and the Apexi SITC, oh and the direct wire feed to the new 040 fuel pump.
Edited by Tangles
Ok, just a couple more comments on the systems I have seen:
The Tisonics one has a digital tilt sensor option for preventing wheel theft. It calibrates itself each time the car is armed to prevent false triggering. I very much like the idea of this feature to prevent anyone floggin my rims. Any other systems that have this feature would be of great interest.
George at Adelaide Prosound's greatest claim when I saw him the second time was that he's 'never had a car stolen or towed away'. Can anyone vouch for this? It's a big claim, but if he can set them up that good however well there has to be something going for him on the installation side of things.
Ok guys went to GT Autosound today & had a bit of a chat with the guys there, very professional from a sales perspective & they seem to really know what they're doing too.
The car's been booked in for surgery there next week. Thanks for your help everyone :O
I didn't actually get the name of the guy, but I'd say he was the boss. I ended up going for the autowatch system, I'd already seen it & liked it, so when he recommended it too I went for it.
He offered it at a good price & could do other parts in the job that appealed to me. Will let you know how it goes, but sounds good :O
Edited by JazzaR33
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
