I've heard a fair bit of talk about hollowing out/punching out the CAT in the hope of gaining some power. Now to me this sounds highly illegal given emission laws but I'd think it'd be hard to tell if done right? Has anyone done this themselves, if so what process, did you open the cat or remove the insides through the holes, did you gain any power? What are the risks etc etc.
Cheers
https://www.sau.com.au/forums/topic/131904-hollowpunched-out-cat/
  • Replies 74
if you tap it with a spanner or something solid it will ting if its empty
so its pretty easy to tell if its been gutted
also youll have black crap on the rear bar where the muffler comes out
obvious signs of a gutted cut or "hi flow" special cat
Woah, that's steep... How would they know though? I was under the impression that it would look stock from the outside and if you get told to go do an emissions check you'd just replace it with a stock one?
i was thinking of the same thing for a while. then common sense hit in and i bought a hi flow. $360 vs $9k. i think it speaks for itself. from what ive been told u just crack it open at the welt joints gut it and weld it back up. if you can get a straight through pipe and then weld a 3" cat cover over it you will get more out of it.
yeh gutted standard one would flow better, but a hi flow one couldnt be much worse, considering larger size in and exit pipes (not adapted from 2 " to 3", and far better flow design.
Although you could always say youve never had it off and i cant see hoe they could prove it wasnt the last owner
someones a hippy.
Perhaps spend a few hundred bux and just buy a 4" cat and put that in instead, the extra size surely wouldnt restrict a 3" system. But i admit having cool flames from the sil80 when it was minus a cat was cool fun when doing mountain runs haha.
I believe they measure the temp before the cat and than after the cat, there should be a drop as it passes through.. also - it'll flame on backfire..
It's not worth it, there is other things you can do to get power that doesn't cost you $10k in fines..
You don't have too be a hippy at all too have a little respect.
Seriously, its generally accepted that not having a cat/gutting your gut with net you about 3-4rwkw - Really worth it.
Now......Time too pour my excess race fuel into Waragamba Dam.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
