One more thing arose out of my trip north of the border - WHO'S BRILLIANT IDEA WAS IT TO MAKE THE SECTION OF FREEWAY BETWEEN BROOKLYN AND MT WHITE A 90 ZONE? and WHY? You can scream down the other side (from Syd to Brooklyn) at 110, but you can't do it from Mt White? What kind of twits do you guys have setting speed limits up there? (probably related to the twits in Vic who put double white lines on a straight piece of road, and then switch to a single broken line as you approach, and drive around, a blind curve)
https://www.sau.com.au/forums/topic/13200-syd-newc-freeway-q/
there is no camera there. the only camera on the freeway is @ Ourimbah as you come down the hill. It is very well marked and you can see it any time of day on ur left. I believe it also gets traffic coming up the hill on the other side as it's infrared.
Just remember if u speed through @ night and there is no flash, you will still get done
You reckon that's FUBAR? I'll tell you what's FUBAR! The old set of traffic lights on the M5 at Moorbank! 110 to 80 then to a red light. There were so many accidents cause traffic would build up to the 110km/h section and people flying would have to jam on the brakes from 110 to 0 when they realise there is a traffic jam.
Finally someone grew a brain and removed them.
it 90 cause of the speed different between truck and cars there
and alot of up the bum no babies crashes
also why does everyone sit in the middle lane there? (left lane is always the quickest up the hill)
dont the rules say keep left unless overtaking
"not in the ***n middle"
pete
im going up tomorrow so ill check the shiet out...
but as far as i have seen tosh is right.... only the one at ourimbah which is clearly marked and easily seen... (on left if going towards newy)
other than that the other cams are just traffic cams...
though soetimes in that 90 zone they have coppers hidden in the twisty bits with big stone faces.... me and franks almost got caught but thankgod the car in front was doing the limit or KABOOOOOOm boost would have gotten us in trouble...
I've travel the F3 from the Coast to Sydney every day and the only camera is heading North Bound near Ourimbah.
There is no camera in the 90K zone from Mt White to Hawkesbury only the RTA Monitoring cameras.
The reason it's a 90 Zone, is that of the entire freeway, that particular section goes from 2 lanes to 3 lanes so many times that there was always cars trying to outrun trucks before they merged and there was always accidents. While there are no FIXED cameras in the 90 Zone, there is pretty much always a mobile unit.
Oh, and the sign that says, "Keep Left unless overtaking", that IS law, you can get booked for not keeping left, as I found out on the M4 on Boxing day 2 years ago heading up to the Blue Mountains. on the fine under the offence it said "Disobeying the Keep left unless overtaking sign" $180 and 2 points later.
  • 4 weeks later...
The length 90km/h zone on the F3 is classed as a "Black Spot". I know its hard to believe that that section is a black spot but having attened some of the prangs there its justified.
The speed camera at Ourimbah can only get nth bound traffic, same as all speed cameras due to privacy laws they cant take a pic of the front of the vehicle, but, they are trying to change it!
privacy laws???, i thought it was cause the flash can blind ya for a few seconds if photos r taken from the front.....anyway as soon as technology is there they'll be doin it, oh and i still say theres a camera in the 90 zone, going to auto salon this w/e and will check it out.
out dudes
lenno
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
