Hi guys
New to SAU & skylines. I would be greatful if someone has any advice or recommendations on lowering my stock R34 GTT S2 4dr. :ninja: I will have my new R34 within a week (being transported from QLD) and the first thing I would like to do (after getting it registered) is lower it so it does not look like big foot! :P
I know after market coilovers (bilsteins or equivalet) would be the best solution, but I cant afford the $1400+ price tag. My question is: Does the S2 R34 have standard coilovers and can they be adjusted at all? Or I have read somewhere on SAU that King Springs are a cheaper alternative to lowering than coilovers? What else would be an option? I only intend to use the R34 as a street car so fully adjustable suspension is not a priority at this stage.
Any help would be much appreciated. :laugh:
See what I mean :)
https://www.sau.com.au/forums/topic/132078-advice-on-lowering-r34-gtt-s2-4dr/
Kings are a cheaper way to go.. But
Keep you eyes open in the parts section of the forums for second hand parts
They are out there .
And if you lucky you may pick up a exhaust of the same guy
Mine was a Big Foot once. Not a new part on it :ninja:
Yes you have to be quick to get the good second hand parts! I will try and keep my eye out. Ok it has one modified part - a 3" apexi cat back exhaust, so looking at getting a dump pipe and high flow cat after it is a decent ride height!! :ninja:
If they came with nismo bilstein option they're you're in luck.
Quote from sydneykid
Hi Howie, from memory the R34GTT Nismo Bilstein option was 15 mm lower than standard, similar height to an R34GTR. You can have the additional circlip grooves added (same as the Group Buy) if you want to go a little lower. I would suggest 3 grooves at 8 mm apart as a maximum. That will give you the potential to go down 24 mm from where they are now (ie; 39 mm lower than standard). They handle best around 350 mm front and 340 mm rear (ie; 30 mm down from standard). So the second additional groove would be the go.
If you want to go that low you will need camber kits, so please keep the following in mind when lowering yours. This is what is usually needed for each height increment, note that all measurements are centre of wheel to guard;
Standard (new) height is 380 mm front and 370 mm rear
360/350 mm needs only the standard rear camber adjusters
350/340 mm needs 1 front camber kit and 1 rear camber kit
340/330 mm needs I front camber kit and 2 rear camber kits
Otherwise keep a look out for nismo bilstein's second hand.
Thanks for all the advice, I would say springs and shocks are the least expensive way to go. Any recommendations on brands apart from Kings or Whiteline? And where is the best place in East Melb to find some? :D
you're best bet would be getting SydneyKids R34 supsension kit.
Bilstein shocks (revalved) and whiteline springs. The guys knows his stuff, and the kid has had some really positive results.
I know for a fact that there are some R34 shocks ready to go at the moment, all revalved, just ready to be shipped.
Kings are $120 a pair i think? so bout $240-50?
like you im still deciding wheather or not to just replace the springs with low kings or whitelines; however i have been checking out Slidewize auctions and you can pickup coilovers pretty cheap. Anyone heard of GAB coilovers?(any good) they seem to be all over the auction at cheap prices.
i dunno, i think that's a nice ride height...
i want to lower mine but if i did that, i'd have to be careful of the cats eyes on the road! my front bar would certainly not allow it..
oh, SK kit includes height adjusting thingies...
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
