Hey guys,
just a quick question, i know i can purchase a hicas lock bar, but i was looking on nengun and they sell an electronic hicas lock kit. I am wondering what are the differences between the two, besides one being pysical and one being electronic.
What is the better option??
thanks guys
Todd
https://www.sau.com.au/forums/topic/132138-hicas-lock-kit/
If you use the lock bar, you can remove the engine bay mounted solenoid, lines and rack, removing about 20 kg i have been told. The problem with this is you disconnect the hicas computer goes a bit heavy at slow speeds.
Using the tomei kit you will lock the hicas and have no problems with steering going heavy, so what i have done is i have bought both, ill remobe the whole system, and install the computer box so i have the best of both worlds.
https://www.sau.com.au/forums/topic/132138-hicas-lock-kit/#findComment-2446865
I just purchased my R33 GTST last week, and i've noticed that the HICAS llight comes on everynow and then.
After reading here, it seems that if that light goes on, then there is problems. However i don't notice any real change in the rear end's stability.
I have an aftermarket steering wheel on it, so referring to the FAQ's it means it wont work properly anyway, but should i get a lock kit (as GTRGeoff provides) and simply forget about the bloody thing?
https://www.sau.com.au/forums/topic/132138-hicas-lock-kit/#findComment-2455070
Yep have just removed mine and installed the lock bar on a R32 GTR and connected up the power steering fluid hoses as per the DIY on this forum.
And apart from the hicas light being on i had no other problems with the removal of the Hicas. And yes just over 20kgs removed from the car doing it this way and i can every change my oil filter and not dislocate every joint in my hand and arm.
https://www.sau.com.au/forums/topic/132138-hicas-lock-kit/#findComment-2455871
as above.
Anyone?
https://www.sau.com.au/forums/topic/132138-hicas-lock-kit/#findComment-2457776
the only real problem is that it causes heavy steering at low speeds after a while of turning the car on.
im currently selling lock bars for $120
GTRgeoff is a good reliable source though, has been selling for a while
PM me if interested.
https://www.sau.com.au/forums/topic/132138-hicas-lock-kit/#findComment-2458268
my car sometimes has a mind of it's own on some roads where there are those kinda ruts? like it's a full proper lane, but just had a lot of use, so there is like a wave in the road. My car will ALWAYS wander whenever there is a wavey road... would that be my HICAS? kinda tramlining of sorts...
https://www.sau.com.au/forums/topic/132138-hicas-lock-kit/#findComment-2458783
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
