  • Replies 51
With my current setup if I dont hold it on redline the value doesnt budge. Past redline , and yeah around 40 or so... Ive had it >120 a couple of times so dont do it too much and make sure I change gears and/or control right foot :-)
I guess what I'm suggesting is that hitting the rev limiter is more likely to increase the knock value on the PFC .. might not necessarily be pinging... the knock sensors are essentially just microphones tuned into a certain frequency.
Edited by Color_Of_Green
Nah, ignition is cut, not fuel. That why you see big backfires on skylines sitting on the revlimiter.
I'm curious, please explain when, where, etc, you have seen high knock on a engine reving at the revlimiter?
Thanks
Um...
It is my understanding that Power FC cuts fuel but Power FC Pro cuts ignition.
Where? my car.
Um...
Where? my car.
Thats correct, we run a pro in the race car and it cuts ignition, part of the launch control, like antilag setup. But yeh, if you brush redline while racing it does tend to spit like a dragon really easy. Thats why i like flat changes, not only does it scare people with massive shotgun noises it looks tough and probably does more damage to everything haha.
just one more question about the knocking guys not that i have understood it but how do u find out if your engine is knocking?
If you have a power fc then you can set the screen on the hc to monitor it with peak hold. You can even graph it as you drive along. Other am ecu's probably have similar features. If you don't have a power fc etc then the only thing you can rely on is an orange flashing light in the top right hand corner of your dash. It will flash on and off when you have a knock of over 60 or there abouts. I was getting knock when in fifth gear and going up a steep hill [retuned now so no longer happens]. The hill was steep enough to make you put the foot down about 3/4 throttle to maintain 100km/h, but no way was the car flat out and no way was it necessary to change gears. I used a trailing throttle to avoid knock on such hills until I got a re-tune.
no it wont do crap, its all wives tales. but yes putting optimax extreme in your stock ecu'd skyline is likely to achieve less detonation, but nothing more. i wouldnt expect much detonation on 98 premium anyway.
Would this alone be a good enough reason to for it? or would the change in knock be so minimal it wouldnt really matter? This is using it over BP 98
As soon as the servo in findon has it I'll be doing a before/after run. Ign/afr (12:1) will be optimized before and after.
I may even fiddle with seeing how it goes leaning it out a touch more. Fingers crossed the egt guage is in by then.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
