Pity there are no strings on the part of the seat where your back is. I find my cover isnt hugging it like it should. Anyone with ideas on how to get it hugging better? Now it looks more like a bench seat....
Yeah, mine is puffy too. I was thinking that you could flip it inside out and sew it to the seat.
I bought these curved needles from lincraft. I'm just really scared to sew. Might poke my finger. My gf is coming over tongiht, i'll make her do it.
So far I have installed the top section of the rear seat now. The way that I found that I could get it the tightest is if I hooked the top over the back section, then started working down with the little white strings.
I have found an issue in relation to the bottom section. Around the seat belt holes, there is onyl a single line stitch. The end stitch will be the weakest link. It basiaclly has begun separately by itself. I've tried to stitch it, but i'm bad at stitching. I might have to bring this issue up with UAT.
PS: Is it just me, or does this take absolutely ages to do?
It took me 6 hours to do the top section of the rear seat. But I am ultra careful.
Edited by 97r33gtst-typeM
I haven't been able to go home all week (my camera's at home). I've been doing the install where i live (student accomodation).
Ok, basically, if you look at the seat belt holes on the bottom section of the rear seat. there is basically only a single line of stitchign going in the direction of the hole, not reinforcing the edge.
When I received mine in the box, I had a look, and basically, the thread had begun to come out already, so the hole was expanding.
Basically, there should be additional stitching to reinforce it. Otherwise, when people sit there, the belt buckle moves, and it'll just rip the hole bigger.
Ok, that issue with the seat belt holes is resolved. My GF stitched it. God bless her hot little heart. She's been so helpful. Oh, and did I mention, she bought them for me as a present too :D
Guys, i worked something out. To take the side plastic trim pieces off the driver's seat and the bolster adjuster, the knob utilises circlips. Hold the knob, and push it with a screw driver, and the clip will pop off.
Guys, got another issue. with the bottom section of the rear seat on the r33, there is that metal loop. How did you guys get around it? Did you cut the cover? up down? left right?
some install tips are here from when i installed them: http://www.skylinesaustralia.com/forums/in...howtopic=124841
also, the guy who started this thread has PM'd me with many questions that i have answered, hoping he puts them on here...
some points
- backrest does not need to be removed. the covers slide over. you have to pull them over gently, moving each side a little bit at a time
- headrests were easy to get off, but tough to get the covers over. again, pull around a little bit each time.
- the issue of headrest install and lumbar knob... its not an issue!
...firstly once the back is all installed and perfect, find the plastic part that is the hole the headrests go into. simply grab a screwdriver and poke a hole through and slide the headrest on. rembmer nothing can be seen once its installed. you are asting your time to take the plastic bits off and try to install them over the covers.. remember they are seat COVERS not a re-trim
.. secondly on the lumbar knob... all you have to do is again locate the knob under the cover then cut a small round hole over the knob. then, simply stretch the hole over the knob. if the hole is smaller than the knob then the material will fall in behind the knob and it will look perfect.
everyone please don't PM me with questions that you have, jsut post them here and i will answer them if i can
cheers,
Warren
Hey Warren,
Just a question, in your post you say the backrest of the seat doesn't need to come off, I'm not sure if I'm useless or what but i cant seem to find anyway at all to get the bottom part of the front seat cover on while the backrest is still connected the bottom of the seat. Now my problem is i cant figure out how to do the bottom section or to pull the seat in to 2 pieces.
I undid the seat belt plug area and have got the right hand side of the backrest of the passenger seat disconnected to the bottom part, but i don't have a clue on what to undo from the other side.
And anyone with an r32 gtst , how do you pull the rear seat out, i checked the bottom seat i cant find any bolts or anything, i give it a pull up and theres a little bit of giv, but not enough to allow the bottom part of the seat to come off...
Someone please help lol. I might need someone to come out and give me a hand lol.
Who in Adelaide was invlved with the groupbuy and owns an r32?? and lives in the northern suburbs. hahahaha
Thanks
Magik32
Greg
Edited by Magik32
read my first post mate.
Basically, originally, I tried to tak ehte backrest of front seat off. But it's not needed. You DO have to take the headrest off. Wait till i get home, i'll take pics.
PS: also, you should pull those little white strings through the seat for a proper retrim job, rather than just using them as seat covers. I also used contact adhesive to glue them to the seat to make it a retrim insead of just seat covers.
  • 1 year later...
bringing up an old thread. just got me a set of these seat covers and are giving it ago. can you please explain in a bit more details what im supposed to do with the white and black strings? should i sew them through the seat? i have no idea. any one else have any installation pics from previous GB's? couldn't find much through search.
cheers
  • 3 months later...
  • 1 year later...
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
